1. Simon Paterson's Avatar
    Hi all,
    Technology has rebelled on me lately..
    I have a rooted Nexus 7 (original) and for months have been enjoying watching movies via my 1TB portable hard drive using 'Stickmount' and 'ES explorer'
    Recently the hard drive began to fail while transfering from my PC so i send it back and got a new identical hard drive. Unfortunately although nothing has changed on the Nexus it wont detect the new hard drive (Stickmount says searching when its plugged in but thats it)
    Ive checked USB debugging is on, changed format on drive from NTFS to exFat and FAT32.
    Any idea whats happened?
    08-06-2013 07:25 AM
  2. gollum18's Avatar
    If your drive is formatted as exfat, android won't pick it up. As android (thanks to Microsoft being greedy), doesn't have support for that filesystem.
    Keep it NTFS, fuse, a well known windows filesystem compatibility program for Linux is built into android and it should work fine. Do not format it as fat32, that is for smaller filesystem's (namely floppy's, and flash drives) and cannot support a filesystem of this size.
    Sent from my SPH-L710 using Tapatalk 2
    Golfdriver97 likes this.
    08-06-2013 09:24 AM
  3. Golfdriver97's Avatar
    Hi all,
    Welcome to the forums!
    Has either app updated? If so it may be the update broke what you are doing.
    08-06-2013 09:30 AM
  4. Simon Paterson's Avatar
    Reformatted drive to NTFS (not quick version) added files to drive that have previously worked, updated to latest version of 'ESexplorer' and still nothing.
    Drive lights up when plugged into Nexus7 via OTG and 'stickmount' pops up saying 'searching' but thats it.. no 'USB storage' listed in 'ESexplorer'.
    Any idea what i can do? / wipe Nexus and start again?
    08-07-2013 12:18 AM
  1. Replies: 17
    Last Post: 04-15-2014, 12:55 PM
  2. Help, manage all outgoing internet connections
    By Somdk in forum General Help and How To
    Last Post: 08-08-2013, 12:01 AM
  3. need help identifying this icon pack
    By sandood23 in forum HTC One M7
    Last Post: 08-06-2013, 12:51 PM
  4. Can't find lockscreen unlock button. Help!
    By Aesthete18 in forum Samsung Galaxy S4
    Last Post: 08-06-2013, 04:31 AM
  5. *Help* - Trouble Linking Google Contacts with Facebook Contacts
    By Mark Liberto in forum AT&T Samsung Galaxy S4
    Last Post: 08-06-2013, 01:00 AM
