Hi, i had a accident with my phone i punched my phone screen out of anger but now the buttons only light up and the screen stays black what do i do?
thank you and no mean comments please.:)
Printable View
You get a new screen installed, or you buy a new phone.
Sent from my Nexus 4 using AC Forums mobile app
Which phone do you have? Connect it via USB to your computer to see if you can still access storage in order to copy any important files, since you will likely have to be without this phone for a while if you get it fixed, or you will be getting a new phone. If your phone has an HDMI output, you could also connect it to an HDTV or monitor (although you might not be able to navigate if the touchscreen function is dead).
