Hi all,
I googled this but could not find the answer. When I use google drive on Nexus 7 fhd to open a mp3 file, it looks the file is downloaded to the device, as the download bar is shown and the file is not played instantly. Also when I turn off wireless, the file can still be played. On the other hand, I can not find the file when I search for the file name.
I want the files be just played over the net, as I do not want to fill the internal memory with these files. So I am confused, if the files are really downloaded to the tablet (which looks to be the case) and if yes, how can I just play the files, without being saved to the device? Also where can I find them to delete them.
Thanks.
Thanks.
