Hey guys!
I have a problem with my nexus 7. A couple of days ago the wifi connection simply stopped working. I just could not turn it on. The wifi icon did not get blue, like it should when it's turned on, and it wouldnt even search for available networks.
So, i thought this might be caused by some bug or software problem and decided to do a factory reset on my nexus 7. The problem is, that did not solve the wifi problem and now i can't even use my device anymore, as it requires a connection for setup.
Does that mean that the problem is caused by hardware malfunction? Is there anything i can do to solve this?
I'm not very experienced with all the android hacking or installing a CFW, or whatever, really just a noob =/
