1. appfro's Avatar
    Hello. I am having a problem with the default reminder in my calendar. when I create a new entry and save it with no reminders, a 10 minute reminder is automatically attached to the event. I have tried several calendars on Google play. business calendar and acalendar for example. this makes me think it's on my phone's default calendar, the one that is being used to sync. I did find settings for default reminders, but I have them all off. I'm not sure what else to do. help please and thank you.
    -Mitch
    08-17-2013 09:52 AM
  2. Scott Kenyon's Avatar
    -Mitch
    Try clearing data and cache from the calendar app.
    Sent from my HTC One using Mobile Nations mobile app
    08-17-2013 12:11 PM
  3. srkmagnus's Avatar
    This should fix the problem. If not, let us know and we'll try and problem solve with you.
    Scott Kenyon likes this.
    08-17-2013 12:14 PM
  4. appfro's Avatar
    Hi guys. Thanks for the responses. I tried your suggestion in an number of variations and sequences to try to get the reminder to stop popping up. I was not successful.
    I've tried: (clearing = clearing cache ; AC = android calendar ; BC = Business Calendar)
    clearing AC - setting default reminder to none - clearing BC
    clearing BC - clearing AC - setting default reminder to none
    uninstalling BC - clearing AC - setting default reminder to none - installing BC
    uninstalling BC - clearing AC - disabling AC - enabling AC - setting default reminder to none - installing BC
    Please note that Business Calendar's default setting is for no reminder. I've also made sure there are no other calendar's installed. The issue is very easy to replicate. I create a test event in BC, wait 20 or 25 seconds (if i go in before that the reminder isn't there yet), and the reminder is there. Always set to 10 minutes. If you have any other suggestions, I'm all ears, and again thank you for your other responses and your attempts to help.
    -Mitch
    08-20-2013 09:41 AM
  5. Scott Kenyon's Avatar
    -Mitch
    I agree with your assessment. Try this:
    Log into your Google account from a PC or Mac, go to Calendar.
    Go into your settings, navigate to calendars, click on the name of your calendar, then reminders and notifications.
    Remove all reminders.
    Let us know if this works.
    08-20-2013 02:47 PM
  6. appfro's Avatar
    GENIUS! That worked. Thank you so much, I would have never found that and it was driving me crazy.
    08-20-2013 03:11 PM
  7. Scott Kenyon's Avatar
    Glad to be of service!
    08-20-2013 08:57 PM
  8. buffalowind's Avatar
    worked for me too. Thanks. Steve
    04-01-2014 10:06 AM
  1. Default Picture and Music Storage to SD Card
    By cmc2 in forum Verizon Samsung Galaxy S4
    Last Post: 04-07-2015, 10:48 AM
  2. Replies: 9
    Last Post: 09-26-2013, 02:47 PM
  3. T-Mobile S3 won't get past "Samsung" screen after factory default
    By MrYankeeFan in forum T-Mobile Galaxy S III
    Last Post: 08-16-2013, 09:12 PM
  4. Location based reminders not working
    By dustlane in forum AT&T Galaxy S III
    Last Post: 08-15-2013, 12:43 AM
  5. Location based reminders
    By NavBrat97 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 08-14-2013, 10:21 PM
