flashed a cyanogen mod rom to my gs3 and i used mpcs rom. it works but my data is weird
I have a straight talk gs3 and I flashed a metro PCs cyanogen mod to it. Did doing so switch my data to the metro towers? Its gone from 4glte to sometimes 3g. Its basically sprint so would it be a good idea to flash it back to a sprint stock ROM? Thanks. Please answer ASAP
Re: flashed a cyanogen mod rom to my gs3 and i used mpcs rom. it works but my data is weird
All depends on the radio files (if included) in the ROM you flashed. That is also the same piece that can cause a perma brick if it isn't the correct firmware.
