1. icedconnor's Avatar
    I have a straight talk gs3 and I flashed a metro PCs cyanogen mod to it. Did doing so switch my data to the metro towers? Its gone from 4glte to sometimes 3g. Its basically sprint so would it be a good idea to flash it back to a sprint stock ROM? Thanks. Please answer ASAP
    08-18-2013 02:47 PM
  2. Paul627g's Avatar
    All depends on the radio files (if included) in the ROM you flashed. That is also the same piece that can cause a perma brick if it isn't the correct firmware.
    08-22-2013 10:43 PM
  3. Jeremy_Collinsworth's Avatar
    I wouldn't personally flash anything else, I would just flash the proper straight talk modem if you can find it. Is it the sprint model gs3? If not, can you give us the model number please? And by straight talk modem, I mean the one it's supposed to have installed that's compatible which is why I need the model number.
    08-22-2013 11:28 PM
  1. HTC one won't find my Samsung tv
    By zorrowaz in forum HTC One M7
    Last Post: 08-18-2013, 04:19 PM
  2. Replies: 0
    Last Post: 08-18-2013, 02:45 PM
  3. Unicorn to the Rescue Game Review
    By themikishow in forum Android Games
    Last Post: 08-18-2013, 02:24 PM
  4. Carhome Ultra and Car Mode
    By DocB1973 in forum Verizon Samsung Galaxy S4
    Last Post: 08-18-2013, 02:19 PM
  5. AT&T claims it's 4GLTE network is more reliable than Verizon
    By dpham00 in forum General Carrier Discussion
    Last Post: 08-18-2013, 02:16 PM
