1. Nicole Cribby's Avatar
    help!!! cant recieve txt messages on my galaxy ace saying no room ive deleted everything i can still not working
    08-18-2013 07:22 PM
  2. B. Diddy's Avatar
    According to the specs I looked up, the Ace comes with very little internal storage (158 MB). This internal storage is used for app installation as well as storage of a lot of app data like text messages. If you have a lot of apps installed, you might not have much room in internal storage for text messages. Also, if you have a lot of text message threads that you've been saving, that uses up storage as well (especially if they have photos or videos in them).
    Can you post a screenshot of your storage screen (Settings/Storage)? If not, can you type out the numbers you see there?
    If I'm right, then I would suggest uninstalling any app you really don't need, and deleting all saved text message threads.. Hopefully, that will clear up enough space for your text messages.
    08-18-2013 09:06 PM
  1. dropped galaxy s4 phone
    By maryfrazier in forum Samsung Galaxy S4
    Last Post: 06-30-2016, 01:32 PM
  2. Galaxy S4 and SD card that suddenly starting causing phone issues
    By Budabud1 in forum General Help and How To
    Last Post: 08-21-2013, 11:25 PM
  3. Help..galaxy s4
    By keilolo40 in forum General Help and How To
    Last Post: 08-19-2013, 12:43 AM
  4. Galaxy S4 Lag
    By FreeSamples0011 in forum Samsung Galaxy S4
    Last Post: 08-18-2013, 06:13 PM
  5. Top of Galaxy S4 screen unresponsive.
    By Victor Cashes in forum Verizon Samsung Galaxy S4
    Last Post: 08-18-2013, 05:07 PM
