1. BIGLEX911's Avatar
    So recently i picked up the LG Marquee and the Boost Force to go along with my ZTE Warp. For some reason when I would go to connect my Marquee through usb i would get the message "Usb Device unrecognized" and that it has malfunctioned. I tried to download the drivers, but received no luck. My Warp seemed to be fine so i swapped out the SD card for the mean time. Then i received the Boost Force and I ended up restoring my laptop and now none of the phone want to work and they give me the same malfunction message. Any solutions?
    08-25-2013 08:49 PM
  2. Golfdriver97's Avatar
    Welcome to the forums!
    Where did you look for the drivers? That should have worked.
    08-26-2013 11:49 PM
  3. BIGLEX911's Avatar
    I actually had a big brain fart and forgot to throw away a broken usb, so the usb was causing the problems xD, thanks for you welcome
    08-28-2013 04:51 PM
  4. srkmagnus's Avatar
    Good to see you were able to resolve the problem quickly. If you have any other questions don't hesitate asking, we're here to help.
    08-28-2013 06:14 PM
  5. Golfdriver97's Avatar
    Oops...Lol
    At least you figured out what was wrong.
    Hope to see you around the forums.
    From a SlimROM S3
    08-28-2013 06:43 PM
  1. Moving files from PC to phone via USB in Mass Storage mode
    By nemesszili in forum Legacy Android & Other OS's
    Last Post: 08-26-2013, 08:19 AM
  2. Nexus 7 2013 QI tablet nightstand charger with speakers and USB port.
    By Gaidin43 in forum Chargers and Batteries
    Last Post: 08-23-2013, 07:17 AM
  3. usb connection
    By sai potla in forum Samsung Galaxy SIII I9300
    Last Post: 08-23-2013, 05:11 AM
  4. is the usb cable that comes with chromecast power only?
    By colonelcack in forum Google Chromecast
    Last Post: 08-21-2013, 06:06 PM
  5. Replies: 0
    Last Post: 08-21-2013, 02:21 PM
