11-13-2013 01:51 AM
30 12
tools
  1. B. Diddy's Avatar
    In the AC Forums thread, the only way I know of to see your threads is to tap the upper right More button, select your Profile, then tap My Posts. Unfortunately, it only shows your 20 most recent posts.
    The Android Central App (the one that also includes the news stories) is generally better--you get the option to see "Participated Threads," which I think goes back as far as the last 200 threads you've participated in. Check it out!
    09-17-2013 11:35 PM
  2. douglerner's Avatar
    To be honest, either Android App is best if replying to a message because the Android Chrome reply field is difficult to input in at this site. However neither app is good for just looking around and catching up on what's happening. I find both incredibly hard to get around in, and always ending getting jumped out back to the home screen. So for just seeing what's happening and generally catching up, like I'm doing now, I just do in on my computer instead of on a mobile device.
    doug
    09-23-2013 11:08 PM
  3. B. Diddy's Avatar
    It's important for the Android Central App developer to be aware of feedback like yours, because he's actually quite responsive, and continues to improve the app. We've all been able to see your progress with Android so far with your very detailed and well-written posts, and someone in your position is exactly the kind of person whose issues and concerns should be brought to light, since you're still in the process of getting accustomed to Android. Post your concerns about the Android Central App in this forum: http://forums.androidcentral.com/android-central-apps/
    09-24-2013 12:36 AM
  4. douglerner's Avatar
    Thanks. I'm loving my Nexus 7 so far.
    doug
    B. Diddy likes this.
    09-24-2013 12:58 AM
  5. douglerner's Avatar
    As I'm getting more used to the Android Central app I'm appreciating it more. I just recently discovered the tiny little triangle that lets you find the thread you participated in.
    Nothing really new to report. Just that I'm finding it easier to use.
    I wish I could figure out all the punctuation for voice dictation, but that's for another topic.
    11-13-2013 01:51 AM
30 12
  1. [TIP] Set up a user profile to act as a 'Chromecast remote'
    By Patrick Schroedl in forum Ambassador Guides, Tips & How-To's
    Last Post: 10-26-2013, 11:02 PM
  2. Replies: 17
    Last Post: 08-26-2013, 11:32 AM
