1. HeyBanana's Avatar
    Hi guys . I wanted to update my android, so i just update my software . After that my phone turned off and on then there were downlaoding with picture of android and box .
    So then it finished and my phone turned off and now i cant turn it on ... so help me please what should i do
    08-26-2013 09:11 AM
  2. Scott Kenyon's Avatar
    What device are you using?
    08-26-2013 09:50 AM
  3. Golfdriver97's Avatar
    Welcome to the forums!
    How did you update your device?
    To try to turn on the phone again, try pulling the battery for a few minutes.
    08-26-2013 10:15 AM
  4. HeyBanana's Avatar
    Samsung Galaxy S Advance, setting then information about phone <--- ( i dont remember exactly) then there were like update software so i tap that ...
    08-26-2013 11:12 AM
  5. Scott Kenyon's Avatar
    Will your phone power up at all? If we can get it into download mode, we can fix it.
    Sent from my HTC One using Mobile Nations mobile app
    08-26-2013 11:16 AM
  6. HeyBanana's Avatar
    sooooo what should i do ?
    08-26-2013 11:20 AM
  7. Scott Kenyon's Avatar
    Try to boot into download mode. Hold home + volume down + power. Tell us the result of this.
    Golfdriver97 likes this.
    08-26-2013 11:32 AM
  8. HeyBanana's Avatar
    no chages .... no signs of live
    08-26-2013 11:56 AM
  9. srkmagnus's Avatar
    If you can boot into Download Mode as Scott mentioned you can get restored.
    Here is a thread on XDA that shows you how to use Odin and uses the stock firmware as an example. By following the instructions you should be able to get the stock firmware re-installed onto the device and get booted. Before moving forward with the process, verify that your model number is GT-I9070 and I would suggest reading through the thread to understand what you are doing: [GUIDE] How to use Odin for GT-I9070 - xda-developers
    Note - you will need to download the stock ROM from the link provided. Be sure to download the one specific to your region.
    If you have questions let us know.
    08-26-2013 11:59 AM
  10. Scott Kenyon's Avatar
    If you plug it into the wall, does it appear to charge or not?
    08-26-2013 12:00 PM
  11. HeyBanana's Avatar
    it doesnt ((( ill try do all of what u said guys again but tomorrow i have to go .... ill tell tomorrow ..
    Huge Thank you Guys !!!! see you later
    08-26-2013 12:04 PM
  12. Scott Kenyon's Avatar
    I don't think there's much else to do. People with HTC Ones have had a similar problem without a firmware update. What worked for some of them was waiting for the battery to totally drain, then charge the device again. It worked for a few people and they were able to get back into the phone. In your case, I'm not sure if this would be of any benefit. If you decide to try it, make sure when you boot up the phone you do it with the key combination I said above and get into download mode. You can then use ODIN to push on the correct firmware for your device and restart it. Follow the directions srkmagnus posted.
    You could also try to contact your carrier and Samsung to see if they can be of any assistance. As long as you never rooted and rommed your phone they may be able to do something for you.
    08-26-2013 12:08 PM
  13. B. Diddy's Avatar
    Try leaving the phone on the charger overnight, then pressing and holding the power down for at least 20 seconds.
    Scott Kenyon and Golfdriver97 like this.
    08-26-2013 04:03 PM
  1. Help: My HTC Likes doesn't work
    By Lejla Husic in forum HTC Wildfire S
    Last Post: 01-27-2014, 12:25 PM
  2. Conflicted between between phones to get, help?
    By CarlosQ in forum General News & Discussion
    Last Post: 09-03-2013, 12:45 PM
  3. Newbie - Help needed! Cannot update S4
    By S4Man in forum Samsung Galaxy S4
    Last Post: 08-26-2013, 03:20 PM
  4. URGENT HELP NEEDED: Change from jelly Bean to ice cream sandwaich
    By kesh.govender in forum Legacy Android & Other OS's
    Last Post: 08-26-2013, 08:53 AM
  5. help with equalizer for music app in ICS
    By xstar47 in forum Legacy Android & Other OS's
    Last Post: 08-26-2013, 08:15 AM
