I'm getting a warranty replacement phone. Regarding Apps, if I go to Playstore and log in on the new phone, will I just be able to download the apps again?
You can log into your Google account and have access to all the apps you've ever downloaded or paid for. If you want to install the same apps on the new device and have the data then you will need to use an app to backup this data then restore on the new device. Keep in mind that most require you to root the phone. There is one - https://forums.androidcentral.com/e...=com.koushikdutta.backup&hl=en&token=UtwL63Gi allows you to backup app data without root.I'm getting a warranty replacement phone. Regarding Apps, if I go to Playstore and log in on the new phone, will I just be able to download the apps again?
