1. kenorian's Avatar
    I'm getting a warranty replacement phone. Regarding Apps, if I go to Playstore and log in on the new phone, will I just be able to download the apps again?
    08-28-2013 11:32 AM
  2. Tele_Phone's Avatar
    Yes
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    08-28-2013 11:38 AM
  3. srkmagnus's Avatar
    You can log into your Google account and have access to all the apps you've ever downloaded or paid for. If you want to install the same apps on the new device and have the data then you will need to use an app to backup this data then restore on the new device. Keep in mind that most require you to root the phone. There is one - https://play.google.com/store/apps/d...a.backup&hl=en allows you to backup app data without root.
    Golfdriver97 likes this.
    08-28-2013 06:28 PM
  4. Golfdriver97's Avatar
    I agree with magnus. Log in with your Google account that is the same on your other device, and it shoudln't be a problem.
    08-28-2013 10:47 PM
  1. I want to root my LG Optimus S 2.3.3 LS670ZVJ
    By kiritosao in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 03-08-2014, 03:12 PM
  2. When is Chromecast coming to Canada?
    By kuler22 in forum Google Chromecast
    Last Post: 10-27-2013, 07:14 PM
  3. Did I need to Root for free hot spot?
    By CallerHoller in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 09-03-2013, 02:58 PM
  4. Battery usage and needed app --- active notification
    By worldsoutro in forum Motorola Droid MAXX
    Last Post: 08-28-2013, 10:36 AM
  5. Google search not responding to voice command?
    By PhobicCarrot in forum Samsung Galaxy S4
    Last Post: 08-28-2013, 09:36 AM
