1. ummdav1d's Avatar
    So, I have my app notifications set on vibrate except the one that I want sound for at night. I can't put the phone on vibrate or mute at night because then the push notification for the app will be muted also, so I want to leave the phone on "Sound" but somehow be able to quickly make the ringtone silent for when I go to bed and then in the morning put it back to what it was without going through settings each time and digging through my list of sound files. Thanks
    08-28-2013 01:07 PM
  2. garublador's Avatar
    I'm pretty sure Tasker can do this. Llama might be able to as well and it's free and more battery friendly, but less powerful if you plan on tinkering more.
    08-28-2013 01:25 PM
  3. ummdav1d's Avatar
    Thank you very very much! I had fiddled with Llama, but I couldn't get it to do it! Just downloaded Tasker and it seems like a very robust app. I just made a button widget for each setting for now and it does exactly what I need... but I may try to improve on that and delve into the app a little more. Seems great. Thanks again!! Very much appreciated!
    08-28-2013 02:49 PM
  4. garublador's Avatar
    You can have it do it automatically if you want, too. I have my phone get quiet if it's between 9pm and 6am and if my phone is plugged in. When I unplug it it,or it gets past 6am, it waits 10 minutes (in case my wife is still sleeping) and then sets the volume back to normal. You can mitigate any battery hits you take by having it on by using Synker (which can be controlled through Tasker) to auto sync a lot less.
    If you haven't already, check out these articles:
    Overview of Pocketables Tasker articles
    The power this app has, especially if you include plug-ins, is incredible.
    08-28-2013 03:00 PM
  5. ummdav1d's Avatar
    Thanks!!!
    08-28-2013 05:47 PM
  1. com.android.phone error
    By Smidge710 in forum AT&T Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 02-06-2016, 03:42 PM
  2. How to turn off notification sounds when on a phone call?
    By slowmandroid in forum Legacy Android & Other OS's
    Last Post: 11-10-2015, 10:34 AM
  3. Rooted my phone, now... questions and issues
    By UncleChewie in forum AT&T Galaxy Note 2
    Last Post: 09-12-2013, 01:53 AM
  4. Apps to Replacement Phone?
    By kenorian in forum General Help and How To
    Last Post: 08-28-2013, 10:47 PM
