1. jsw9261's Avatar
    Hi
    I tried to flash gtr 7.8.6 rom to lg optimus one phone according to the instructions but now it is stucked at the lg logo screen.Pls help.
    08-30-2013 02:16 AM
  2. Paul627g's Avatar
    Sounds like a bad flash or possibly the need for a kernel to be flashed?
    If you can get back to your custom recovery you can try to wipe and flash again.. Hopefully you made a backup before you encountered these problems?
    srkmagnus and jsw9261 like this.
    08-30-2013 12:29 PM
  3. srkmagnus's Avatar
    Yes, reload a backup if you have one. Otherwise, read the instructions in full and make sure nothing else needs to be flashed, such as a kernel like Paul suggested.
    Sent from my SPH-D710 using Tapatalk 2
    jsw9261 likes this.
    08-30-2013 06:21 PM
  1. Replies: 10
    Last Post: 04-21-2017, 05:26 PM
  2. HELP. screen not showing
    By adlx21 in forum Verizon Samsung Galaxy S4
    Last Post: 08-31-2013, 08:26 AM
  3. Any ideas why after I unlock screen it does not register my first screen press?
    By spacolin in forum Samsung Galaxy S4 Google Edition
    Last Post: 08-30-2013, 04:18 PM
  4. Need help - lost system - phone won't boot.
    By allan473 in forum Sprint Galaxy Note 2
    Last Post: 08-30-2013, 10:03 AM
  5. Replies: 0
    Last Post: 08-29-2013, 08:16 PM
