1. sweeeeetheart's Avatar
    i bought note 2 since 4 months . last week it stops charge ... i changed bettery ... still same ... changed charger ...still same .. BUT!!! now sometimes charges good and sometimes it shows that charging and it lighing red but it in fact it dose not charging.... and what drives me crazy is sometimes it charges good !!!! by the way phone is not rooted it still new i use it rarly....
    08-30-2013 05:54 PM
  2. sweeeeetheart's Avatar
    08-30-2013 06:00 PM
  3. srkmagnus's Avatar
    Did you resolve the issue? Not sure what you were trying to say in your second post.
    Sent from my SPH-D710 using Tapatalk 2
    08-30-2013 06:05 PM
  4. sweeeeetheart's Avatar
    no i did not resolve,sometimes it charge well and mostly not...
    08-31-2013 05:36 AM
  5. B. Diddy's Avatar
    When you say you changed the charger, do you mean you changed both the USB cable and the plug? Or is it a charger with a permanently connected plug? If they're separate and if you only changed one of the components, it's possible that the other is faulty.
    Otherwise, it sounds like it might be a problem with the charging port. You might want to contact Samsung for information on how to get it repaired under warranty.
    08-31-2013 01:18 PM
  1. Just ordered a Note. Coming from a One.
    By superbleester in forum AT&T Galaxy Note
    Last Post: 09-05-2013, 06:20 AM
  2. Replies: 17
    Last Post: 09-01-2013, 08:29 PM
  3. AT&T Galaxy s4 drops LTE on calls???
    By 305rob305 in forum Samsung Galaxy S4
    Last Post: 08-30-2013, 09:26 PM
  4. Sync Xoom with Galaxy S4
    By RoyceP in forum Motorola Xoom
    Last Post: 08-30-2013, 06:09 PM
  5. S4 wont stop group messaging!!!! How?
    By thepolster in forum Samsung Galaxy S4
    Last Post: 08-30-2013, 03:30 PM
