1. darksparten's Avatar
    Motochopper+others appear to be broken, judging from a google search.
    Do I NEED an SD Card, or is there another way?
    09-02-2013 08:06 PM
  2. josiahlikesminecraft's Avatar
    I believe that u can root it without a SD card.
    Posted via Samsung S3
    09-02-2013 08:09 PM
  3. darksparten's Avatar
    Specific link to method please
    thanks
    09-02-2013 08:20 PM
  4. josiahlikesminecraft's Avatar
    Alright let me find it.
    09-02-2013 08:28 PM
  5. josiahlikesminecraft's Avatar
    09-02-2013 08:29 PM
  6. josiahlikesminecraft's Avatar
    09-02-2013 08:31 PM
  7. srkmagnus's Avatar
    I don't have an S4, so the process is a bit new to me. However, looking over the information provided by DroidXcon (http://forums.androidcentral.com/sam...galaxy-s4.html) it does not look like you need an external sd card. All you need is to download the files, which can be handled by the internal sd card or preferably the desktop pc, then connect your device to a pc and follow the instructions.
    IF you need help take a look at the above thread and post there or let us know here what problems, if any, you are having.
    09-03-2013 10:14 AM
  8. darksparten's Avatar
    Josiah's method no longer works on the new firmware.
    How To Install CWM Recovery on AT&T or Verizon Galaxy S4! [SGH-i337/SCH-i545] | GalaxyS4Root.com
    I tried srkmagnus's method, it doesn't work>.> At least for me. At the end of the batch file script it will say
    Failed
    Cleaning up...
    Success, you are rooted, press enter to reboot!
    Then, superuser will ask me to update su binaries on reboot, and say "superuser failed to update, please send log to developer"
    Rootchecker says im not rooted
    09-03-2013 08:10 PM
  9. ruxanity's Avatar
    Yep, this is how far I got. Don't have any micro SD cards so I'm waiting for a soft solution.
    09-18-2013 02:15 AM
  1. New S4 Charging Time
    By stealth2920 in forum AT&T Samsung Galaxy S4
    Last Post: 12-07-2013, 08:50 AM
  2. Replies: 4
    Last Post: 09-12-2013, 06:05 PM
  3. Missing radio after rollback to 4.2.2 from 4.3
    By Sophie Li in forum Legacy Android & Other OS's
    Last Post: 09-07-2013, 11:25 AM
  4. Move apps from N7 to N4
    By gtt1 in forum Google Nexus 4
    Last Post: 09-03-2013, 07:11 PM
  5. Replies: 3
    Last Post: 09-02-2013, 08:27 PM
