1. npark2012's Avatar
    Hi all,
    So I just got Paranoid Android on my Galaxy Nexus i9250 and I was messing around with PA Colors and clicked apply it did what it said it would by changing the color of buttons and notification bar but I don't know how to set it back to how it was before the apply. And I don't know if this is related but when I try to change to tablet UI or any other UI for that matter it does nothing. I hit apply it says "Applying, please wait" then after it's done it says "Superuser granted to Input Devices" before I changed the PA Colors it would change into the tablet UI but now it won't. Can anyone help me? I'm new with PA.
    09-03-2013 10:10 PM
  2. ketan koul's Avatar
    There is an option of STOCK UI in hybrid properties. That should set you back to stock. Also, the change to tablet UI would reflect on how certain apps look on your device. I think it is better to have your device on stock and then have individual settings for each app. That gives you more control and avoids messing up apps that do not work fine with changed resolutions. #Myopinion.
    09-10-2013 12:28 AM
  3. npark2012's Avatar
    That doesn't help because I specifically said it wouldn't save the settings whether stock, phone, phablet or tablet UI. It would just revert back to the previous option.
    09-10-2013 06:33 PM
  4. Golfdriver97's Avatar
    I think a reset would help that out.
    Sent from a SlimROM S3.
    09-10-2013 09:18 PM
  5. npark2012's Avatar
    I just gave up on PA. Even if I reset it would eventually not work even if I don't touch anything. So I'm just running cyanogenmod right now. Oh well..
    09-11-2013 12:52 AM
  1. WTS/WTT VZW Galaxy Note II w/ lots of extras
    By svenEDGE in forum Marketplace Archive
    Last Post: 09-06-2013, 12:03 PM
  2. Re-watch the KitKat Android unveiling video!
    By chram893 in forum Android 4.4 KitKat
    Last Post: 09-05-2013, 02:40 PM
  3. Not New To Android
    By danialgoodwin in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-04-2013, 02:25 PM
  4. Replies: 3
    Last Post: 09-04-2013, 09:01 AM
