1. sotirios7's Avatar
    Hello i have samsung galaxy s4 4.3 update last version and i got one problem when i call someone dont show me ''complete action with''....i search in forums a lot about mine problem i try unistall install again the skype viber etc....reboot.....wipe chache.....reset factory......go to settings>application manager>all>clear default ...and still nothing....its any bug of 4.3 version?Anyone with same problem?I check from S voice from there when i try call shows me complete action with skype,viber....i dont know how to fix its crazy...!
    09-06-2013 07:31 AM
  2. SpookDroid's Avatar
    Since the 4.3 update for the S4 hasn't OFFICIALLY been released, it would be good to know which ROM you're using so that those with the same one installed could help. But it sounds like it's a problem with TouchWiz's dialer. Have you tried using a third-party dialer and see if that works?
    09-06-2013 07:48 AM
  3. srkmagnus's Avatar
    I'm not quite sure I follow your question. Do you not want the phone to ask which action you want to complete the action with? If this is the case, make sure you check the "always" box so the action you choose is what will be set to default the next time you want to make a call.
    09-06-2013 09:29 AM
  4. sotirios7's Avatar
    sry i have 4.2 mine mistake....and i want mine phone ask me when i want call someone to show me complete action with skype viber as every time did....after mine mistake check always and now call without show me this message....i search on forum for fix it and i tried unistall/install......reset settings factory....wipe chache......download other programm for call....went settings>manager application>all>viber,skype,telephone nothing for clear default....can anyone suggest me how can i fix it?another solution?
    09-08-2013 01:17 PM
  5. srkmagnus's Avatar
    Goin to the phone app in the application settings. There might be an option to "clear defaults". Choose that and see if that allows you to complete action with your App.
    Sent from my SPH-D710 using Tapatalk 2
    09-08-2013 05:10 PM
  1. How is this device performing with Android 4.2.2 ?
    By David Alfredo in forum Samsung Galaxy S3 Mini
    Last Post: 09-27-2013, 08:47 PM
  2. AT&T Samsung Galaxy S III Will Not Boot
    By droidguy15 in forum AT&T Galaxy S III
    Last Post: 09-08-2013, 10:47 AM
  3. How to disable the GPS on the Google Nexus 7 FHD?
    By lsquare in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-07-2013, 08:13 PM
  4. Replies: 0
    Last Post: 09-06-2013, 06:52 AM
  5. How to return the nexus 7 (for replacement) and what to include.
    By nexme in forum Google Nexus 7 Tablet (2012)
    Last Post: 09-06-2013, 06:50 AM
