1. Ziya Chhetri's Avatar
    I need help whenever i plug my charger in the screen always says dock mode connected and then for a second it turns on then turns off then turns back on continuously. How do i disable dock mode.
    09-08-2013 09:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! What device are you using? Dock Mode generally shouldn't come on unless you plug in the appropriate connector. Are you using your original charger, or is it a 3rd party charger? If the latter, then maybe something about how the plug is designed is incorrectly making the device think it's a dock plug.
    09-08-2013 10:36 AM
  1. HTC One Desk Top Mode
    By Mad Jack in forum Verizon HTC One
    Last Post: 09-27-2013, 10:08 AM
  2. Replies: 8
    Last Post: 09-23-2013, 12:52 PM
  3. Generic hub or dock with SD card reader, Ethernet and USB port?
    By openweb in forum General News & Discussion
    Last Post: 09-08-2013, 06:49 AM
  4. HELP! Samsung S2 4G - Odin Mode
    By Emzibubble in forum General Help and How To
    Last Post: 09-07-2013, 12:04 PM
  5. Retrieving text messages sent during flight mode
    By mountainlife in forum Samsung Galaxy S4
    Last Post: 09-07-2013, 11:34 AM
