1. nenechef's Avatar
    Hi, i hope someone can help me, i got a transparent icon in the notification bar is like a submarine o balloon, but the weird thing is just in the lock screen, when i enter in the home screen the icon disappear but coming again on the lock screen, some one knows what can be???,
    Katie Garcia1 likes this.
    09-12-2013 02:44 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Can you take a screenshot and post it so that we can actually see the icon? To take a screenshot, press the power button and the volume down button at the same time.
    09-12-2013 03:36 PM
  3. nenechef's Avatar
    09-13-2013 06:42 AM
  4. EvilMonkey's Avatar
    Your screenshot didn't come through. Can you try again?
    09-13-2013 07:04 AM
  5. nenechef's Avatar
    Odd icon on notification bar-new-image.png I hope you can see now Click image for larger version.
Name:	New Image.PNG
    09-14-2013 08:57 AM
  6. DenverRalphy's Avatar
    I'm pretty sure that's a lightbulb from your wallpaper bleeding through your semi-transparent status bar, and not an icon.
    B. Diddy and nenechef like this.
    09-14-2013 10:05 AM
  7. B. Diddy's Avatar
    Agree.
    Funny expression!
    09-14-2013 11:38 AM
  8. nenechef's Avatar
    Thank you for you answer, but even changing the wallpaper and with a normal status bar, this stay there
    09-14-2013 12:10 PM
  9. B. Diddy's Avatar
    Is it always there, or only when the status bar is shown? If it's always there, it might be a screen defect.
    09-14-2013 12:13 PM
  10. nenechef's Avatar
    it is always and only in lock screen, not in home screen and it is just from 4 days ago, i didn't add any app or nothing, just come from nowhere
    09-14-2013 12:52 PM
  11. B. Diddy's Avatar
    It really looks like one of those other light bulbs. I suspect that somehow that current image has somehow gotten "stuck" in the status bar. If I knew what system app was responsible for the lock screen and/or the status bar, I'd suggest you go to Settings/Apps/All and clear its cache, but I'm not really sure which one it would be.
    One thing to try would be a cache partition wipe, which erases temporary data that the system uses. The process is a little different for each device. What device are you using?
    09-14-2013 12:56 PM
  12. nenechef's Avatar
    i am using Samsung galaxy s4, android version 4.2.2, system app Nova launcher, already i clear the cache still the same
    09-14-2013 01:23 PM
  13. B. Diddy's Avatar
    Did you actually clear the system cache partition, or just the app cache? To clear the system cache partition, you have to reboot into the Recovery Menu. Did you do that?
    Also, have you tried reverting back to the stock launcher, or temporarily uninstalling Nova?
    09-14-2013 01:28 PM
  14. nenechef's Avatar
    how can i do the reboot into the recovery menu?? already i uninstallling nova
    09-14-2013 02:18 PM
  15. B. Diddy's Avatar
    Instructions here: How to Enter Recovery Mode on the Samsung Galaxy S4 - TheUnlockr
    When you're at the Recovery Menu, select "Wipe Cache Partition." Don't worry, you won't lose any important data. When the cache wipe is done, highlight "Reboot System Now" and press the power button to execute.
    nenechef likes this.
    09-14-2013 02:39 PM
  1. Art on your tablets?
    By johnathan clemens in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-03-2014, 10:16 PM
  2. Disable screen on for sms?
    By justlaxin13 in forum LG G2
    Last Post: 09-01-2014, 12:50 PM
  3. '! HOT APPS !' app Randomly Appeared on my Phone
    By homer119 in forum Legacy Android & Other OS's
    Last Post: 09-13-2013, 04:01 PM
  4. Drawing on your nexus 7 tablet?
    By johnathan clemens in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-13-2013, 01:37 PM
  5. Replies: 0
    Last Post: 09-12-2013, 02:42 PM
