1. whatsvictory's Avatar
    Ok so I've encrypted my Rugby and have run into some issues where I can't install new apps or update my current ones without using Rom Toolbox. In ES Explorer all the folders/files are in randomizes numbers so I can't see the actual floder names. Of course this is a problem.
    I am using TWRP and CM 10.1. I have tried differnt things to do this and nothing works. I have tried to do a rest from the in-phone options and from recovery which I was told before I encrypted would work. I have tried running "mke2fs -t ext4 /dev/block/mmcblk0p12" (encryption - Cannot Factory Reset after Encrypting - Android Enthusiasts Stack Exchange) from adb shell in Linux and it doesn't work (though I am wondering if I chose the correct device in the command and don't know how to determin the correct one ) as well as deleting the stored credintials as instructed off of another forum where someone one was having the same problem. So I'm stumpped.
    I have been looking for a way to completly delete the encrypted internal sd but all I seem to be able to find is instructions for things I already know don't work. All I have been able to find are the basic reformat instructions that formats each individual partition and I'm thinking I need to delete the entire partition table just to wipe this puppy out and add new partitions myself unless I can get conformation that the CM 10 install will do this on it's own.
    I need some pointers. Over all the phone works ok I can call, text and get on the net but I'd like to be able to update and install new apps. when I try to update or install I get an Insufficient storage error.
    Thanks in advance.
    09-15-2013 01:22 PM
  1. got any application can download you tube movie and save in note 8.0?
    By carrick_lau16 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 09-22-2013, 12:35 PM
  2. Can you imagine...
    By Haalcyon in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 09-20-2013, 07:48 PM
  3. Need Drivers for Samsung Galaxy Ace GT-S5830i
    By Zahid Eqbal in forum Legacy Android & Other OS's
    Last Post: 09-17-2013, 12:15 AM
  4. Can anyone recommend a good charging pad?
    By Chris_L23 in forum LG G2
    Last Post: 09-15-2013, 12:52 PM
