indestructibleguy
Hello everybody; I hope i'm in the right place of this forum to post my question ..
I'm into shifting to android world for the first time, and never experienced the work or use of any android device. Now that i'm going to use an Android smart-device, I know that I have to re-purchase all the apps I had purchased on my iPhone. i'm just concerned about the bookmarks I have on my current iPhone apps, particularly the ones I have in my LDOCE app (Longman Dictionary of contemporary English). If I bought the upcoming Galaxy s4, how could I transfer all the bookmarks? Also, is there any way to sync the accounts I have for the apps i'm going to purchase?
thanks
As far as I understand, apple and android run on different systems (obviously), so the apps run in different formats. Because of that, I'm very sure that importing/exporting bookmarks (unless they're saved online in the app database) would be more trouble than it's worth. If your dictionary app does have an online account that you have/had to log in, check under the settings for 'save bookmarks online' or something of the sort. If the bookmarks are saved to your phone offline, and can't be put online, then I'm afraid you'll have to input them all over again by hand.
