Google Ply stuck on Skype demo
Hi all,
Just downloaded Skype from the Google Play store and after downloading it is displaying a series of demo screens that I can't seem to close.
Every time I open Google Ply it goes to these screens rather than the store.
Phone is Samsung Galaxy Note II
GJ
Re: Google Ply stuck on Skype demo
Welcome to Android Central! When you open Google Play on your phone, press the back button. Does that get you back to the main screen?
Otherwise, go to Settings/Apps/All, scroll to and select Google Play Store, and tap "Force Stop." Then open Google Play like you normally would.
Thanks, the back button wasn't showing but the Force Stop fixed the problem.
