1. JoDee Abbott's Avatar
    I purchased this phone on Ebay and found out it came from China. I got a very small manual with it about 4 pages. How do I find a manual for my phone? My smart phone is smarter then me. I have searched the web and did not find any downloads. I really would like to use my phone and all its features. Thanks, JODEE
    I had to edit this post. My phone is android 4.0.3
    09-23-2013 03:23 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings/About Phone, and tell us what the Model Number is. Frankly, though, if a manual exists for your phone from China, it will either be in Chinese, or possibly very poorly translated English. This thread might end up being more helpful: http://forums.androidcentral.com/gen...ps-tricks.html
    09-23-2013 03:28 PM
  3. JoDee Abbott's Avatar
    e1809c_v15_zhl_1328 is the model number
    09-23-2013 04:01 PM
  4. Rukbat's Avatar
    Sounds like one of those kinda-sorta-Android phones coming out of China the past year or so. About the only "manual" you really need, if you're not familiar with Android, is the link B. Diddy gave you. Android phone hardware is pretty much all the same for a given generation and carrier.
    B. Diddy likes this.
    09-23-2013 04:38 PM
  1. Replies: 6
    Last Post: 09-25-2013, 02:32 PM
  2. Anyway to hide 3G icon in status bar?
    By Distant Deviant in forum General Help and How To
    Last Post: 09-24-2013, 02:34 PM
  3. Replies: 8
    Last Post: 09-23-2013, 07:26 PM
