1. Shahbaz Talpur's Avatar
    I want to replace "System/lib/modules" and "Sysltem/lib/hw" with the other ROM's modules and hw folder. I simply copy pasted but I am getting installation aborted error in CWM. Any help please?
    09-28-2013 10:53 AM
  2. srkmagnus's Avatar
    You need to make sure the property read/write permissions are set. You can set the permissions with root accessible file manager Apps, such as Root Explorer. I'm not familiar with setting the proper read/write permissions for these types of mods, so you may need to ask in the root/hack forums or check with the developers of the ROMs you are pulling from.
    09-28-2013 11:52 AM
  3. Paul627g's Avatar
    To add to what skrmagnus said, swapping of lib files and other configuration files is a tricky deal. Many times its trial and error and other times it takes modifying then to work properly with the device and OS.
    Sent from my HTC One using AC Forums App.
    09-28-2013 12:00 PM
  4. Shahbaz Talpur's Avatar
    ROM developer said me to replace those files. When I flash through CWM I get error. So why should I set permissions with file explorers?
    09-28-2013 03:20 PM
  5. srkmagnus's Avatar
    Did the ROM Developer package the files for you to flash with CWM? If you are trying to flash with CWM yourself without packaging the files in a signed .zip then you'll get errors and the files won't flash.
    Shahbaz Talpur and Paul627g like this.
    09-28-2013 10:18 PM
  6. Shahbaz Talpur's Avatar
    Yeah, that was mistake.
    09-30-2013 10:16 AM
  1. How does an AT&T Moto X work on T-Mobile?
    By CANE8081 in forum Moto X (2013)
    Last Post: 10-29-2013, 06:43 AM
  2. How do I change the text message settings?
    By Treeroy in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-13-2013, 05:25 PM
  3. Replies: 27
    Last Post: 10-02-2013, 09:49 AM
  4. sd card files to phone, then back to sd card...
    By Distant Deviant in forum General Help and How To
    Last Post: 10-01-2013, 12:49 PM
  5. Unrooting HTC One X/Returning to Stock
    By justein in forum HTC One X Rooting, ROMs, & Hacks
    Last Post: 10-01-2013, 09:33 AM
