1. standi22's Avatar
    hello
    as the title says, the alarm does not sound when my tablet goes into sleep mode until I turn it on and without unlock it, is at this moment that it begins to sound even if the time go over
    this is the case with many applications alarm, for the moment I use Alarm Clock Plus
    I have a Chinese Android tablet with Jelly Bean 4.1.1 rooted
    I don't use any task killer
    thank you
    09-28-2013 12:57 PM
  2. Distant Deviant's Avatar
    You could just set it not to go into sleep mode and plug it in so it stays on charging and will wake u up.
    "Our business is life itself."
    -Umbrella Corp.
    09-28-2013 01:30 PM
  3. standi22's Avatar
    but the screen will stay on all the night
    09-28-2013 02:07 PM
  4. Distant Deviant's Avatar
    But ull have it charging, u could dim the screen or flip it over :T
    -Umbrella Corp.
    09-28-2013 03:20 PM
  1. How to see the calls history from a contact?
    By Paul VAYSSIERE in forum Google Nexus 4
    Last Post: 03-20-2014, 02:49 AM
  2. How do I change the text message settings?
    By Treeroy in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-13-2013, 05:25 PM
  3. [New][Free] TOILET PIANO crazy sounds :D
    By mibejo in forum Android Games
    Last Post: 10-05-2013, 10:03 AM
  4. Replies: 27
    Last Post: 10-02-2013, 09:49 AM
  5. [Q] How to replace few files in ROM?
    By Shahbaz Talpur in forum General Help and How To
    Last Post: 09-30-2013, 10:16 AM
