Hello i recently tried to root my phone, and when i got to the recovery state my phone would just open with a black screen. i pulled the battery out but it still opens with a black screen. Can i get any help with this?
02/034/2013 04:34:05 - INFO - <- This level is successfully initialized
02/034/2013 04:34:05 - INFO - Flashtool Version 0.9.11.0 built on 2013-06-04 22:50:00
02/034/2013 04:34:11 - INFO - Device connected with USB debugging on
02/034/2013 04:34:12 - INFO - Connected device : SonyEricson Xperia Mini Pro
02/034/2013 04:34:12 - INFO - Installed version of busybox : N/A
02/034/2013 04:34:12 - INFO - Android version : 2.3.4 / kernel version : 2.6.32.9-perf / Build number : 4.0.2.A.0.62
02/034/2013 04:34:12 - INFO - Checking root access
02/034/2013 04:34:13 - INFO - Root Access Allowed
02/035/2013 04:35:19 - INFO - Selected Xperia MiniPro (SK17i) / 4.0.2.A.0.42 / HU
02/035/2013 04:35:19 - INFO - Preparing files for flashing
02/035/2013 04:35:20 - INFO - Please connect your device into flashmode.
02/035/2013 04:35:56 - INFO - Device disconnected
02/036/2013 04:36:43 - INFO - Device connected with USB debugging off
02/036/2013 04:36:43 - INFO - For 2011 devices line, be sure you are not in MTP mode
02/043/2013 04:43:35 - INFO - Device disconnected
02/052/2013 04:52:36 - INFO - Device connected with USB debugging on
02/052/2013 04:52:37 - INFO - Connected device : SonyEricson Xperia Mini Pro
02/052/2013 04:52:37 - INFO - Installed version of busybox : N/A
02/052/2013 04:52:37 - INFO - Android version : 2.3.4 / kernel version : 2.6.32.9-perf / Build number : 4.0.2.A.0.62
02/052/2013 04:52:37 - INFO - Checking root access
02/052/2013 04:52:37 - INFO - Root Access Allowed
02/053/2013 04:53:11 - INFO - Flash canceled
02/053/2013 04:53:21 - INFO - Selected X10 / V1 / BLRelock
02/053/2013 04:53:21 - INFO - Preparing files for flashing
02/053/2013 04:53:21 - INFO - Please connect your device into flashmode.
02/053/2013 04:53:23 - INFO - Flash canceled
02/053/2013 04:53:29 - INFO - Device disconnected
