Hello, after the troubles with my last tablet I had it switched (extended warranty came in handy this time) from a Visual Land Prestige 7L to Visual Land Prestige Pro 7D. While downloading the same apps I had on the older one I came across an issue that is where my question came from. I play a fair amount of app games and am fond of the ones from Mobage Games but most of them says 'Your device isn't compatible with this version' which confuses me as this tablet is supposed to be an upgrade, faster and all that. Is there any work around for this or some other way to see why there is a compatibility issue? I know this is the risk with lesser known tablets but budget wise it's also a risk that saves me some $$, so thank you to any help or directions if I'm in the wrong spot.
