1. quakquakquak's Avatar
    Samsung tab GT-P1000 is stuck, I tried the factory reboot, wipe data and reboot, nothing is working, is it a brick now? Please anyone help??? Galaxy Tab GT P1000 - samsung tab is STUCK. PLEASE HELP-20131007_213251.jpg
    Peppi Zahra likes this.
    10-07-2013 08:56 AM
  2. Paul627g's Avatar
    Looks like you still have an option available. You will need to locate the "restore to stock/factory firmware" for the device which is used with an application on your computer called Odin. Using this will restore your device back to as it appeared out of the box, new.
    quakquakquak likes this.
    10-07-2013 09:02 AM
  3. quakquakquak's Avatar
    Odin also no reaction after i plug it to the computer....I don't know what's wrong
    10-07-2013 09:11 AM
  4. Paul627g's Avatar
    Do you have the proper Samsung drivers installed? Also try different ports, one one the back of the computer/laptop are right on the motherboard and normally your best option. The other "remote" ports are wired and usually don't give a consistent connection for Odin.
    10-07-2013 01:18 PM
  5. Peppi Zahra's Avatar
    what was wrong with your tablet mate.i have the same problem .i have galaxy tab p-1000.cheers
    10-24-2014 09:15 AM
  6. Peppi Zahra's Avatar
    what was wrong quakquakquak with your tablet mate.i have the same problem .i have galaxy tab p-1000.cheers
    10-24-2014 09:16 AM
  7. B. Diddy's Avatar
    Welcome to Android Central! It's been a full year since this thread was updated by the OP, so it's unlikely he will respond. Are you having the exact same problem that he described? No variation?
    10-24-2014 09:18 PM
  1. Galaxy Note 10.1 - Sd card
    By wingman1800 in forum Samsung Galaxy Note 10.1
    Last Post: 10-16-2013, 10:52 PM
  2. Galaxy Note 3 - Coming from an iPhone
    By sddabrow in forum Samsung Galaxy Note 3
    Last Post: 10-10-2013, 12:40 PM
  3. Galaxy s3 lte i9305
    By Shaun Russell in forum General News & Discussion
    Last Post: 10-09-2013, 10:46 AM
  4. T-Mobile SGS 4 - need help determining repair part
    By Armorplays in forum T-Mobile Galaxy S 4G
    Last Post: 10-07-2013, 09:18 AM
  5. Galaxy Note 3 - Verizon Canceled My Pre-Order
    By Connert in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 08:26 AM
