1. Arrowhead123's Avatar
    My Galaxy S4 screen is just completely black. I can turn on my phone and even put in my pattern code on the screen, but it remains black. I have tried to reset it multiple times and I don't really know what to do. If there is a possible fix without having to get a repair I would like to know, but if you do have a suggestion I will gladly accept it.
    10-08-2013 11:27 PM
  2. AMOCO's Avatar
    So you don't have a launcher?Can you pull down the navigation bar to get to the settings?
    Sent from my N9100
    10-08-2013 11:45 PM
  3. Arrowhead123's Avatar
    Guessing that you are talking about my phone the answer is no. I cannot see anything on the screen at all. It is just completely black. The phone does turn on and it works as if it is fine, but I just cant see anything on the screen.
    10-09-2013 08:54 AM
  4. Zubaru25rs's Avatar
    My GS4 just did this, what did you do to fix it?
    12-26-2013 01:32 PM
  1. Menu key not lighting up!! help please!!
    By PHONERESTORer in forum Verizon Galaxy Note 2
    Last Post: 10-09-2014, 11:52 AM
  2. I suck im not worthy! lol please help!
    By Philip Clark3 in forum LG Optimus Elite
    Last Post: 11-18-2013, 05:14 PM
  3. Need some help with 4G
    By Meg Goforth-Ward in forum LG Optimus G Pro
    Last Post: 10-10-2013, 01:27 PM
  4. Google Play Store bug. Please help.
    By Nuuq in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 10-09-2013, 08:57 AM
  5. Need to send back phone/screen is black/can't factory reset
    By newuserII in forum General Help and How To
    Last Post: 10-08-2013, 09:17 PM
