1. webb's Avatar
    I have no problem transferring HD movies to my card but songs I'm having problems,I'm trying using a MacBook into a Note 2,I've heard that the micro card should be FAT32 ? I have no clue how to do it.
    Should I use Windows instead of Macs ?
    Any help is appreciated.
    10-12-2013 10:09 AM
  2. Rukbat's Avatar
    SD cards come formatted as FAT32. Exactly what problems are you having? (The transfer may just be timing out because it's handling the transfer as one huge block instead of many files. Transferring a smaller bunch of files at a time may work better.)
    10-12-2013 12:19 PM
  3. B. Diddy's Avatar
    Actually, my 64 GB microSD from Transcend came formatted in exFAT, which isn't compatible with Android (at least, not with my Razr Maxx). I had to reformat it to FAT32 using my phone, since for some reason my Windows 8 laptop wouldn't give me the option of FAT32--only exFAT and NTFS. You can format the card to FAT32 by inserting it into your phone, and if it says the format is incompatible, it will probably give you the option of formatting the card--say OK (as long as you don't have any important data already on the card).
    Chinaphonearena likes this.
    10-12-2013 01:39 PM
  1. Audio Problem
    By smifaz in forum Legacy Android & Other OS's
    Last Post: 11-10-2013, 05:02 AM
  2. Play Store: Missing List of Installed App
    By thisismelol in forum Google Nexus 4
    Last Post: 10-15-2013, 12:38 PM
  3. Smart Phone Flash Tool Root problem
    By Adnan Shole in forum Legacy Android & Other OS's
    Last Post: 10-12-2013, 10:05 AM
  4. How do I incorporate this phone into my life!!!
    By joan006 in forum Samsung Galaxy Note 3
    Last Post: 10-12-2013, 09:30 AM
