1. andgle's Avatar
    OK, so with the nexus 5 coming out soon I was wondering if indeed it does support Verizon's network can I take my micro sim card out of my Verizon gs3 without deactivating the gs3 and put it in a UNLOCKED nexus 5 if it supported Verizon and will it work?
    I think this should work but I need clarification so thanks for the help in advanced.
    10-14-2013 04:59 PM
  2. Aquila's Avatar
    No, that won't work. Bringing a device to Verizon involves them adding the device IMEI to their database. It would have to support their CDMA bands in order to receive calls and have anything other than LTE, and it would have to support their LTE bands to have LTE service. Unfortunately for now, the only surefire way to have a device work on Verizon is to buy a device that was made specifically for Verizon.
    10-14-2013 05:08 PM
  3. paul-c's Avatar
    Only Nexus phone that works on Verizon is the Galaxy Nexus. Don't expect to see anything else from Google to work on their network anytime soon.
    Sent from my Sony Xperia ZL now Free
    10-14-2013 05:36 PM
  4. andgle's Avatar
    OK thanks but your saying if the nexus 5 did have the right bands to support Verizon's LTE it would work if I put my sim card in on the network but just would be able to make calls.
    Or did I miss interpret that.
    10-14-2013 06:48 PM
  5. Aquila's Avatar
    I think that it would still have to be added specifically to Verizon's network, but someone with more knowledge on that part can chime in.
    10-14-2013 06:50 PM
  6. Rukbat's Avatar
    Assuming that Verizon added the phone's IMEI to their database, if it's a GSM phone, it would only work on LTE, not on voice or text, since they're still CDMA and the phone isn't.
    But since they're not going to add the phone you buy to their database, it won't do anything at all.
    andgle likes this.
    10-14-2013 08:35 PM
  7. andgle's Avatar
    OK thanks for the answers they help a lot.
    10-14-2013 09:26 PM
  8. moosc's Avatar
    And no the nexus5 doesn't support current vzw lte bands. So the only way to use it is as a Wi-Fi device
    Sent from Bad Azz VZW LG G2 Cyan Tapatalk
    10-14-2013 09:31 PM
  9. bigmatt503's Avatar
    If the nexus 5 did come to verizon you could just swap out sim cards. I swap phones on occasion and have never contacted Verizon.. I doubt the nexus will Be coming to Verizon (we can hope though)
    Sent from my rooted droid razr using Tapatalk
    andgle likes this.
    10-14-2013 09:34 PM
  10. gone down south's Avatar
    Correct ....... Except that you would have to call Verizon and have them switch the phone in their system too.
    Sent from my Nexus 4 using AC Forums mobile app
    10-14-2013 10:00 PM
  11. bigmatt503's Avatar
    Well..... I have never had to call Verizon to swap from my 4G phone to another 4G phone.. When I log onto my Verizon it shows what ever phone I am using at the time.. Again, I have NEVER called in.
    Sent from my rooted droid razr using Tapatalk pro that I had to pay for twice!!
    10-15-2013 11:39 AM
  12. Aquila's Avatar
    Hello..
    I just upgraded my HTC Hero from 1.5 to 2.1... On my old setup, on one of my homepages, I had a "favorites" box which was arranged as nine contacts and had their pictures. I could quickly click on one and it would initiate the default contact method, call, text, etc.
    On 2.1, I notice the favorites has been moved in the People App and it is now a group.
    I cannot find any way to get the favorites back on one of my homepage screens. Can someone help?
    Thanks
    Dave
    Have you ever tried with a device that's not in their system and/or doesn't have the antenna and radios to work on their network? That's what a nexus is.
    XT1060. Through spacetime.
    andgle likes this.
    10-15-2013 04:09 PM
  13. andgle's Avatar
    Wow thanks for the info that saved me from possibly loosing $400.
    I am curious has anyone tried swapping sim cards to a phone not in the Verizon database?
    10-15-2013 05:05 PM
  1. Should I buy a Nexus 4, 5 or 7?
    By zoidberg22 in forum Google Nexus 4
    Last Post: 11-19-2013, 02:12 PM
  2. Bad imei/esn on the new AT&T S3 I just bought!!!!
    By paulmagglios in forum AT&T Galaxy Note 2
    Last Post: 10-26-2013, 08:44 PM
  3. can't see the 3 buttons in landscape mode
    By yuvalnyk in forum Google Nexus 7 Tablet (2013)
    Last Post: 10-19-2013, 10:46 AM
  4. my screen always on while charging 😱
    By mima mimi in forum HTC One M7
    Last Post: 10-16-2013, 03:12 PM
  5. Missing features in new SNOTE app?
    By double07#WN in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 10-14-2013, 06:49 PM
