1. andgle's Avatar
    So I am wondering if you had a phone, say the nexus 5 and if that phone did support Verizon's network (I know it most likely won't but if it did) but it was an unlocked nexus 5 and wasn't in the Verizon database could you just put a micro sim card in the nexus 5 and would it work for at least LTE coverage?
    10-15-2013 05:09 PM
  2. trivor's Avatar
    The short answer is no - all you have to do is look at the problems the Nexus 7 has had - it is designed for Verizon with Verizon LTE Bands but it hasn't been "approved" so there is no way to activate it. Now, some users have said if they have an activated SIM from another phone and put it in the Nexus 7 then the Nexus 7 will work. Also, it must have a CDMA radio in it because this is how you will make calls on the Verizon network.
    10-15-2013 05:24 PM
  1. my S3 does not pick up the wifi signal
    By beauwhale in forum Samsung Galaxy S3
    Last Post: 07-21-2015, 03:27 AM
  2. Anyone else use the Note 3 exclusively in landscape orientation?
    By AdamHLG in forum Samsung Galaxy Note 3
    Last Post: 02-08-2014, 01:24 AM
  3. Home icon no longer in the center of the page bar
    By limoman in forum Sprint Samsung Galaxy S4
    Last Post: 10-15-2013, 10:32 PM
  4. New to Android. Question on a few things
    By HiMynameisMattyK in forum Samsung Galaxy Note 3
    Last Post: 10-15-2013, 06:38 PM
  5. Help transfer pictures from old phone?
    By gummyjelly in forum LG G2
    Last Post: 10-15-2013, 05:32 PM
