1. droidmess's Avatar
    Hello, I have ,I guess is a generic android 4.0 . Anyway, I am having a terrible time sending messages it always says unavailable right now . Now it has a red triangle with a exclamation point in it and my messages aren't being sent,they come back to me. I changed a number ,but I don't know where it was. Can anyone help me?
    10-15-2013 09:15 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    Did you change your phone number?
    From a Sprint Moto X using AC forums app
    10-16-2013 12:17 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! We need more information. What wireless provider are you using, and what country do you live in? Was it working fine before? Did you recently get a new SIM card? Are your voice calls working ok? Are you only having problems sending, but still receiving messages from others? What do you mean by "I changed a number"?
    10-16-2013 12:37 AM
  4. droidmess's Avatar
    No I didn't change my number. I did see where I am getting a error 313 know anything about that?
    10-16-2013 05:52 AM
  5. droidmess's Avatar
    My provider is straight talk. I live in the USA. well actually it was hit and miss depending on the signal strength. I got the sim card when I went with byop with straight talk, it's been a few weeks now'
    Actually here is what happened I seen a (what I thought wwas a phone number on what sim number} well I changed that to myphone number. I know really dumb. Anyway I started to get this alert thing a red triangle,well when I click on the tab thing on the left,It said info about alert it said error 313, I have went back to factory settings no good, turned it off then on ,no good, then I took the battery and sim card ot then replaced them still no good. I have know idea what the original number was ,so I tried putting my sim card number in it still no good. I don't think its that serious,I;m just not that smart on this. No I can't recieve text either. I hope someone can help me.
    10-16-2013 06:04 AM
  6. Golfdriver97's Avatar
    You might need to get a new phone number from Straight Talk.
    10-16-2013 08:33 AM
  7. Rukbat's Avatar
    The place you changed the number - what does the phone say that is? There must be some text telling you what type of number is wanted in there.
    10-16-2013 06:16 PM
  1. Galaxy Note 3 - Action Memo to text msg
    By joan006 in forum Samsung Galaxy Note 3
    Last Post: 09-24-2014, 09:30 PM
  2. problem with receiving text from iphones
    By Marsha Holland in forum Samsung Galaxy Note 3
    Last Post: 04-17-2014, 07:38 AM
  3. Replies: 10
    Last Post: 02-27-2014, 03:40 PM
  4. handwriting to text?
    By mynewride in forum Samsung Galaxy Note 3
    Last Post: 10-18-2013, 11:00 AM
  5. Droid MAXX - Emoji plug in for stock text app?
    By skatergirl in forum Motorola Droid MAXX
    Last Post: 10-17-2013, 02:20 PM
