Using CyanogenMod-7.2.0-galaxys2 with a bluetooth headset. If the screen blanks the bluetooth audio cuts off which makes listening to podcasts with AntennaPod rather tricky. Works perfectly with a wired headset. Currently just putting the screen timeout to max and pressing the home button every so often to work around it.
