Green vertical line.
jericho375
5
I know everyone has asked this, but I have a green line (Vertically) about a 1/3 of the way from center to the right. I got my phone when I woke up this morning and unplugged it. I then went back to sleep for 30 minutes, when I awoke I turned on my phone. For a few seconds it was fine but after about 30-40 seconds the line appeared with a flickering gesture, then a consistent line. I immediately shut it off and began research on this and couldn't quite find a solution.
information :
When I take a screen shot it is not there.
I factory reset my phone still no resolve.
It shows up on boot up.
I haven't dropped my phone, even once.
it is a GSM unlock so I cannot return it to the manufacturer.
I do a lot on my phone including gaming, social networking, and watching tv shows/ movies. (could this be the cause?)
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Aside from the green line, you can still use the device normally? I think this might have to do with a bad pixel(s). Where did you purchase the device from? Perhaps the seller can assist you with a repair.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,737
113
Agreed. This sounds more like a hardware problem rather than a software problem.
Mooncatt
Ambassador
Feb 23, 2011
10,754
318
83
I've only encountered this on a couple laptops, and in both cases it was an issue with a circuit board. In one, it was cracked from my cat jumping on it a few too many times. The other, it was a solder connection breaking down and has symptoms closer to what you described. It's ok at first, but it starts having various problems (like the vertical lines you're seeing) as the video card heats up and micro cracks develop in the soldering points. I don't know how likely either of those two problems would transfer to the phone world, but I'd be prepared to spend a fair bit to repair it if it's not under warranty. It's definitely a hardware problem. If you carry it in your pocket a lot, it could be getting twisted and stressed and causing the break/bad connection.
Sleezzyy21
