1. cjl100gs's Avatar
    I have an iPhone 4s and my brother wants to swap his GS3 with me for a couple of weeks to see if he would want to buy an iphone as his next phone. If we do the swap will I be able to use verizon's 4G LTE network or would this not work? Thanks
    10-20-2013 09:30 PM
  2. srkmagnus's Avatar
    If 4G LTE is included in your current package, then yes. I understand you don't have a LTE ready device, but that could be something you are paying for even if you are not using a compatible device.
    Call Verizon and tell them you are about to buy or be given a used LTE device and want to know what you need to connect it to your line. They should tell .
    Sent from my SPH-D710 using AC Forums mobile app
    10-20-2013 09:33 PM
  3. cjl100gs's Avatar
    I still have my unlimited data so it might be included, I'm not sure.
    10-20-2013 09:38 PM
  1. Replies: 8
    Last Post: 10-09-2016, 03:05 PM
  2. Verizon HTC One on AT&T
    By JW4VZW in forum Verizon HTC One
    Last Post: 03-26-2016, 02:19 PM
  3. Daydream question...
    By dhawk1202 in forum Motorola Droid MAXX
    Last Post: 10-21-2013, 05:14 PM
  4. launcher question
    By Dude905 in forum Google Nexus 4
    Last Post: 10-21-2013, 10:34 AM
  5. More icons on a screen
    By redrover69 in forum Samsung Galaxy Note 3
    Last Post: 10-20-2013, 09:20 PM
