1. meloncollie1's Avatar
    Okay well I think my HTC Droid Incredible 2 is not charging because of a loose charger port, but I'm not sure. I ordered a charger port and a battery off eBay just so I could try both. Unfortunately, the battery won't be here until Tuesday and I'm going out of town for the weekend. So I can't test and see if it's just the battery. So where can I take the port to get fixed in time to leave Saturday, Radioshack, Best Buy, those kind of stores? Or can I charge the battery without the phone somehow? Is there something I can buy? I am DESPERATE for answers. Thanks!
    Golfdriver97 likes this.
    10-24-2013 06:38 PM
  2. CR6's Avatar
    You might search "external battery dock or charger". http://item.mobileweb.ebay.com/viewi...d=190581664162 EBay carries them, but that was the first link I pulled up, I'm sure they are available at a number of places.
    Best Buy may be able to repair it, but you should also search for a cell phone repair store in your area. Must cities have them these days. Good luck!
    tap'n
    10-24-2013 06:43 PM
  3. Golfdriver97's Avatar
    Cr6 has a good idea.
    From a Sprint Moto X using AC forums app
    CR6 likes this.
    10-25-2013 12:58 PM
  4. CR6's Avatar
    Let us know how you made out with this meloncollie.
    tap'n
    10-28-2013 11:19 AM
  1. Any way to air play from note 3 to apple tv?
    By rajnet in forum Samsung Galaxy Note 3
    Last Post: 07-05-2014, 02:58 AM
  2. Replies: 1
    Last Post: 10-24-2013, 10:56 PM
  3. HELP!!
    By pammie28 in forum General Help and How To
  4. Replies: 8
    Last Post: 10-24-2013, 08:27 PM
  5. Replies: 1
    Last Post: 10-24-2013, 06:42 PM
