1. FW190's Avatar
    Hi, Might sound a silly question but is there any easy way to answer a call?
    I just got my first android (4.2) phone and find it a complicated procedure to answer calls.
    When I get an incoming call I get a white phone symbol which I have to press and hold to get the red and green phone symbols to appear and to answer a call the timing has to be exact as if I release the white phone symbol before I have started the slide to answer it fails and I find it about impossible to reject a call with this method.
    I thought there might be some setting to alter this like the lock screen but can't find anything.
    11-05-2013 04:05 AM
  2. Fairclough's Avatar
    When I had 4.2 it was tap the centre drag across took half a second at most, is this what you mean?
    - Android Central App. Remember courage is contagious.
    11-05-2013 07:10 AM
  3. FW190's Avatar
    When I get an incoming call all I get is a white phone symbol in the center of the screen.
    I have to press and hold this white phone symbol to get the red and green phone symbols to appear, then to answer a call, while still pressing the white phone symbol, drag the green phone symbol to the center (which is where my left thumb is still holding the white phone symbol) , if I release the white phone symbol too soon the whole procedure fails.
    11-05-2013 07:41 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Can you tell us what kind of phone you're using?
    In general, when you get a phone call, you tap on the phone icon, and then slide toward the green phone symbol to answer, or toward the red phone symbol to reject. So it should just be one fluid motion--press the phone icon with your thumb, then slide to the right. Are you sure you have to tap the green phone symbol and drag that toward the white phone symbol? That doesn't sound right to me.
    11-05-2013 08:39 AM
  5. FW190's Avatar
    That works, thanks very much.
    I hadn't tried anything like that, the instructions are useless, they say you have to slide the red and green symbols in to the center and the white one isn't mentioned at all.
    It's a 'cubot c9+' - cheap chinese unlocked phone.
    B. Diddy likes this.
    11-05-2013 09:36 AM
  1. Replies: 7
    Last Post: 11-08-2013, 11:20 AM
  2. How to enable text messaging
    By Debjeet Barua in forum Legacy Android & Other OS's
    Last Post: 11-05-2013, 09:25 AM
  3. Back to stock kernel
    By Oleksandr Podoprigora in forum General Help and How To
    Last Post: 11-04-2013, 11:49 PM
  4. If i put my Data down to 3g will that save battery over LTE
    By angry english in forum Google Nexus 5
    Last Post: 11-04-2013, 10:31 PM
