Will I lose apps and data of the apps if I root? [Galaxy Tab 10.1 3G running 4.0.4] please reply and can you recommend an app [doesn't matter if it requires a computer as long it works with my tab 10.1] that can backup my apps and data?
I would just back up the apps and keep the files on your phone. Then root.Hmmm, Downloaded Helium app and Helium for Windows followed the instructions from device (PTP mode, Debugging mode etc.) yet still nothing appears on the PC application?
You mean manually copy the .apk's and data of each app?
When Helium/Titanium/My Back Up makes a back up of say, Angry Birds, it actually makes a file. That file is what you should keep on your phone, and if you want, have a secondary on your PC.
If I backup the files to the SD card and perform a Factory reset, will it wipe the data on the SD card?
P.S If I root my Galaxy Tab 10.1 3G, Is there a way to have Jellybean on it? It highest OS is only until ICS 4.0.4 or speed it up or have a better battery life?
No.
Depending on if you like AOSP, you can possibly have 4.3 on Slim.
From a Sprint Moto X using AC forums app
No for not gonna wipe the SD card when I factory reset?
Sorry didn't understand, what do you mean by AOSP and slim? sry noob here
Factory reset should not affect your SD card.
AOSP meaning vanilla Android, like a nexus device. Slim is a proper name for a developer like Cyanogenmod.
Do you know a thread that talks about step-by-step guide on how to root Galaxy Tab 10.1 3G running ICS 4.0.4? I would really like to root, and how can I prevent from bricking my tab?
Not if you copy all the files from the SD card to your computer first. Then you don't care. Having a single backup is good - unless the backup gets corrupted. Having 2 backups almost guarantees that at least one will survive.If I backup the files to the SD card and perform a Factory reset, will it wipe the data on the SD card?
I backed up using Mybackup Pro and Helium app and copied the whole SD card to the computer as well. am I ''qualified'' to root now? xD
Sounds like you are good to go.
Successfully rooted But I would like a JellyBean ROM as I mentioned before, Is it possible to run 2 ROMs at once too? Since I would like a JB ROM and GSM ROM to be able to call using my Galaxy Tab 10.1 P-7500 Pls post with a link of a thread with the things I'm looking for, it's ok if its only a JB ROM TY
