I just found out by accident that the Android OS on a tablet only lets you browse using a mobile version unless you are using pure Google "Android" like in the Nexus 7. I found that you can switch from mobile to desktop with an option at the menu on top of the Nexus 7. But it start up again on the mobile version. Is there an option that you can set up in the setting menu to default always to the desktop?
I trying out Samsung, LG and Kindle 7" and could not change it to desktop format.
What size tablet is required to have a desktop web browsing screen appear?
Is there away to do it in the setup of these other tablets or can you do it with an Android "app".
Coming from both a Windows phone and Apple iPad environment.
Thanks.
Thanks.
