If you are new to Android Central, Welcome! You might already be a member of our sister site,
PreCentral(preware - simple root, patches - to make a simpler, better phone - QUICKER) .
The
webOS Homebrew community has developed hundreds of
patches to add features to "rooted" Palm Phones.
Few were used by Palm, keeping webOS easy to set up. Google added hundreds of these features but that means that there are more options to set up initially. This guide will help you compare the differences and find key features.
← Click the
Getting Started button at the top of every page will take you to the
Getting Started with Android - Tips and Tricks. There is help for everything including
Keyboards,
Applications, etc.
Synergy
Android automatically syncs your contacts and calendar with Facebook, Flickr, Google, LinkedIn, Twitter, and Microsoft Exchange. A friend's photos, status, name and number pops up when they call. If they update their Facebook profile, your Android is updated too. To set accounts to sync: Tap Home > Menu > Settings > Accounts & Sync. Use
Outlook Calendar Sync to sync with your Outlook calendar. See the
Getting Started,
Facebook, Twitter, & LinkedIn Sync for more.
Transferring Contacts to Android
Here is how to
Transfer webOS Contacts to Android.
Multitasking
Android Multitasking automatically saves your work when you go to another app. You can start an email, start a text, open a web page, listen to music, and you can go right back where you left off in the email. Long-press Home to see your last 8 Recent Apps.
Cards
If you miss cards, try Perfect Task Switcher, Visual Task Switcher, Wave Launcher, Itching Thumb or launchers like LauncherPro.
Themes
If you rooted your webOS device, you could install themes. With Android, you do not have to be rooted. Just use a
launcher like
LauncherPro to change icons, backgrounds, etc.
Folders: 3 Taps to 320 Apps
See Folders for details.
One of the most missed features from Palm Treo's is Folders. Android lets you sort your apps into
Folders such as Tools, Multimedia, Games, etc. Tap Home > {Folder} > {App} for any of up to 256 apps.
Browser
See Internet Tips and Tricks for details.
Youd can double-tap on an Android brownser screen or pinch out to zoom.Android "re-flows" and "word-wraps" to fill the space so text is not cut off. Android uses the full screen. THere are dozen of popular
Browsers to consider such as
Dolphin or Opera
Click here for this example:
Official webOS 1.4.5 Discussion.
Android also allows you to have multiple Browser cards open at a time: Tap Menu > Windows > + or long-press a link to open another window.
More Icons
The webOS
4x4 Icons patch allows 16 apps per screen. The Android
Folder Organizer (
free) app lets you have
4x6,
5x6, or
5x7 icons per screen, 20+ apps per folder, and change icons and labels without rooting.
Just Type (Universal Search)
webOS 2.0 Just Type is similar to
Android Search and
iPhone Spotlight. Tap Search and...
• Just type "ma" and Mail, Maps, and every Mark or Mary will pop up.
• Just type "oliv" and your friend Oliva pops up along with local Olive Gardens.
Search also lets you choose what is included: Tap Home > menu > Settings > Search >Searchable Items.
Voice Search
Long-press the Search for
Voice Actions to just say your command or search. (
Introduction Video) You might say: "send text to Bill Byrne let's meet at 6 o'clock on fifth avenue outside the guggenheim museum". Also consider
Vlingo. See
Search for more.
Visual Voicemail
See Visual Voicemail for details. Tap here to see a sample.
Basic webOS
Visual Voicemail apps are available but are limited. The screen below shows a typical Android Visual Voicemail screen with a slider, Play ►, Pause ll , and Delete. Tap Menu to text back or Forward a voicemail or save it to your SDcard.
microSD
Keep your favorite movies, music, and photos with you. Key to
Backups.
16 GB ~$26 -
32 GB ~$55 &
64GB
HDMI/DLNA
HDMI and DLNA allows Android devices to output to HD TV or projector for home theater or business presentations.
• HDMI: Standard to show a presentation, photos, or movie. Adapter cables allow VGA or RCA out.
• DLNA: Standard wireless output to your newer Blue-ray, TV, PS3, etc.
Overclocking
Overclocking forces a phone to run faster than designed. Overclocking voids the warranty and can damage components. While rooted Androids can be overclocked, most already run at 1+ GHz and Android is very efficient. Facebook or Google Maps open on a Pre in about
11 seconds vs about 2 seconds on an EVO.
Notifications
Android
Notifications are in the top bar and take up no screen space. Drag down to see them. In this case, you have missed a call, have 3 new email, have your GPS and 3G on with good signal and it is almost lunchtime.
Swipe the Notifications down and they stay on screen until you tap one or swipe the Notifications up to close them. The
Missed Call apps lets you set different repeating sounds and vibrations for missed calls, emails, and texts. See
Notifications for more.
Lockscreen Notifications
Apps like
Executive Assistant (free) let you see and respond to individual notifications from the lock screen. In addition Executive Assistant allows you to set repeating reminders for missed calls, emails, texts, calendar events, and more. You can set customized sounds, vibrations, and LEDs for each. (
Executive Assistant-No ad version,
Details)
Key Apps
Here are a few more of the many Applications you may want to try.
• Go Contacts lets you dial a middle part of a name or number. For 202-456-1414, you can dial "456" or "1414".
• TouchPal Dialer lets you dial their initals for instance dial 2 for B, 6 for O for Barack Obama.
• Email: K-9 Mail is way better than the stock email app. Get Touchdown if you need Microsoft Exchange support.
• Messaging: Consider HandCent SMS or ChompSMS to replace the messaging app
• Browsers: Consider great options like Dolphin or Opera
• MyBackup Pro ($5) - Automatically backup messages, contacts, bookmarks, homescreens, alarms, dictionary, etc. Trial.
• Folder Organizer (free) - Sets up folders, change icons, and increase from 4x4 icons to 4x6 or even 5x6. See: Folders
• ASTRO File Manager : Install, run edit, & backup apps, etc. much like webOS Internalz
Brightness Level - With two taps, you can change your screen birghtness level.
Widgets
A widget is a live app icon on a homescreen. webOS has one widget: the Calendar app icon updates to show the date.
Widgets can take the space of a single app icon or multiple icons. See the
General Tips & Tricks for how to use widgets to set up an amazing control panel. Beware: some widgets take a lot of battery power. Here are some great Widgets to get you started.
Tajm - The amazing clock widget in words instead of numebrs shown above.
Battery Status (free,
Upgraded $1) - Puts the real battery percentage in the Notification Bar.
The Weather Channel - Puts the temperature in the Notification bar.
• Speed Dial Widget:
Folder Organizer (
free),
GO Contacts (
iPhone theme),
MeContacts, or
QDial.
Battery Left Widget - Estimates battery time left.
Today Widget - Day and date in a 1x1 widget. (
$1 Pro version has color options)
• Curvefish: •
WiFi On-Off •
Bluetooth On-Off •
GPS On-Off
Volume Button Controller – All the volume levels in one place.
Live Wallpaper
Live Wallpaper is animated. The Earth rotates, grasses wave, clouds billow, stars move, fish swim, water ripples, and little robots dance. Practical uses include live GPS and weather maps.
Touchstone
The Touchstone,
Powermat,
Enerergizer Wireless Charger, and
Duracell myGrid are accessories that allow wireless inductive charging (based on Nikola Tesla's
induction patents).
Touch-To-Share
TTS is a type of Proximity Transfer allowing two devices to transfer information. HP
Touch-to-share (TTS) transfers URLs between two HP devices sharing the same profile (
Engadget).
Bump transfers contacts, songs, photos, events,
money, friends, and apps between any two iPhones or Androids.
Near Field Communication offers much more.
Other Considerations
Different Android phones offer many other features:
Screen Sizes: 3", 4", 5", 7", or 10" screens.
Storage: 32 GB microSD card option
Camera: 5 to 8 MP or more, Autofocus, Digital Zoom, Effects
Video Chat: Front camera for Video Conferencing
FM Radio, compass, etc.
If this helped you, please click ↓↓
