1. ChezBurgr's Avatar
    Keep getting error message "SD card unexpectedly removed" the card is still in the phone at this time. Went to Verizon today they inserted a new SD card for me, by the time I got home which was about 5 mins the error message was back. When i go into settings under storage, it tells me to insert a SD card, problem is the card is already in the phone. When i turn the phone off and then restart it is fine for several mins the the error message pops up and i cannot use the SD cardNot sure where to go from here?????? phone is Droid razr x HD
    11-09-2013 04:07 PM
  2. srkmagnus's Avatar
    It could be a hardware issue with the phone and the SD card is not seating properly. Take it back and ask them to replace the device or look at a fix for it. Worst case is that they won't and you'll have to do without an SD card - unless you have insurance and pay for the replacement.
    11-09-2013 08:26 PM
  3. Golfdriver97's Avatar
    Does the phone do well without it?
    From a Sprint Moto X using AC forums app
    11-09-2013 09:56 PM
  4. B. Diddy's Avatar
    Maybe there's some dust or other debris in the SD card slot. Try taking the card out and blowing the slot out with a can of compressed air.
    11-10-2013 01:35 AM
  1. Can deleted photos be recovered WITHOUT having had an SD card?
    By Violet James in forum General Help and How To
    Last Post: 03-11-2017, 02:37 AM
  2. I've gone through 2 memory cards already.....
    By seinx in forum AT&T Samsung Galaxy S4
    Last Post: 11-13-2013, 07:09 AM
  3. SD mysterious unmount
    By Cjanebe in forum Droid RAZR M
    Last Post: 11-11-2013, 09:33 AM
  4. How to have multiple SIM cards?
    By quietlybrilliant in forum Google Nexus 5
    Last Post: 11-10-2013, 01:43 PM
  5. AT&T Ipad Sim Card to work on Nexus 5 Phone
    By Anuj Acharya in forum Google Nexus 5
    Last Post: 11-09-2013, 12:07 PM
