How to stop tugo toggling between wifi and mobile
Hi All, first post!
My Samsung galaxy 3 mini is with o2 and reception at home is poor to zilch and keeps coming and going. I have therefore installed tugo, but the phone keeps toggling between wifi (tugo) and mobile reception, if and when i get it.
Is there a simple way to turn off the phones mobile connection to force it to stay on tugo via my wifi, while at home and then enable mobile connection when I leave home ?
Many Thanks
Tim
Re: How to stop tugo toggling between wifi and mobile
Simple? No.
Turn on Airplane mode. Turn on wifi. That locks you into wifi. Turn off Airplane mode. Turn off wifi. That locks you into the mobile connection.
That's a good method.
Does your phone have a "Wi-fi Calling" option in the Settings? This is available on the Sprint version in the US, and if it's turned on, then I believe the 4G is automatically turned off.
Rukbat, that works for me, thanks very much for the tip. B.Diddy, no Wi-fi calling on my phone but thanks for suggestion.
Regards
Tim
