1. Kelly Shannon's Avatar
    why wont htc sync manager reconize my phone
    11-18-2013 11:52 AM
  2. srkmagnus's Avatar
    Hi Kelly, welcome to the forums!
    What device are trying to connect with HTC Sync Manager? I would first start to make sure your PC meets the minimum requirements, then make sure the appropriate drivers are installed and all connections are properly connected. Also, consider a reboot of the computer and phone just in case.
    Let us know how that goes.
    B. Diddy likes this.
    11-18-2013 12:26 PM
