1. langshan's Avatar
    I am confused about android versions. I have a Huawei U8652 and looking to upgrade.
    Thanks,
    Mike
    11-18-2013 01:28 PM
  2. cpaight's Avatar
    4.01 is newer....4.4 is current
    11-18-2013 01:47 PM
  3. BrainAdventure's Avatar
    in android 2.3.6 they have fixed the voice search issue. Most important features of he android 4.01 are Facial recognition, Better voice recognition , allows up to 16 tabs, Updated launcher. so it depends on the features you are interested in
    11-18-2013 06:15 PM
  1. Verizon Moto X 4.4 Soak tests are beginning which means...
    By SeigaGen in forum Motorola Droid MAXX
    Last Post: 12-15-2013, 08:36 PM
  2. 4.3 Update is live!
    By demon09 in forum ASUS Transformer Pad TF701
    Last Post: 12-08-2013, 05:00 PM
  3. HTC myTouch 4g - Need PD15IMG.zip file.for Android 2.3.4
    By Lori Luther in forum HTC myTouch 4G
    Last Post: 11-26-2013, 07:02 AM
  4. Help Me Choose the Best Android Tablet for the $
    By tess1977 in forum Google Nexus 10 Tablet
    Last Post: 11-18-2013, 10:24 PM
  5. Replies: 1
    Last Post: 11-18-2013, 01:55 PM
