Same here, my Scapbook won't open. Error message says... Unfortunatley Scapbook has stopped.
I got it to work but its a work around not a fix.
As soon as you tap on the Scapbook icon start to tap on the screen several times then click on the OK error message to get one of your saved scapbook pages to open.
I will try to find why this is happening. Hope this helps for the time being.
Ok found the issue within 2 minutes.
When you get into your scapbook scroll through and start to deleted saved notes. Test until you find the one causing the issue. I would start with the last one created. One of mine was causing it to not open. Now it works 100%. Hope this helps
palms
