My Facbook account wont sync with my contacts
Nov 24, 2013
8
Hey there!
I have a Galaxy S4 and I synced all my contacts from Facebook with that of my phone. My idiotic sister logged out of my account without my permission, logged into hers and left it like that. Now my facebook account wont sync with my phone contacts again. Everytime i go to my contacts, tap on options and go to 'accounts' and select my facebook from the list of accounts i've added, the 'sync now' button works but when I click on it it says 'sync disabled'.
I went onto my FB app and looked for account sync options but I couldnt find any. Anyway I can fix this?
Please respond ASAP :)
James Jackson5
Hey
I had the same problem. To fix it you need to go onto your facebook using your device in question. Flicking the screen to the right to reveal the menu panel scroll down to App settings, and right at the bottom of the page it says sync contacts. This will be disabled but if you click on it it gives the option to change the settings. Hope this helps.
Puiman
