I'm researching browsers and gathering information from the web, Google play, ac forums etc. But some "fixed" text won't come up with the option to copy when I long press. I could use some kind of web clipper, but as the research progresses I edit, put some things together to compare, edit out what isn't needed etc.
Is there another way to copy?
Thanks
Sent from my MID using AC Forums mobile app
Thanks
